You could make it fit but it would require changing a whole lot of stuff. Even the transmission bellhousing is different. Too much work. The 429 is better off in a car that came with it. Those engines had a few issues that later Cadillac powerplants didn't. Try for example, sourcing an oil pump. You will find out that the engine went through several redesigns. All the pieces and parts are collector items and if you need something you have to compete with big bux restorers. You could probably sell the engine to a collector and raise enough $$ for something easier to replace that poor little HT-4100.
