hi guys
I've a question.
some time ago i asked because my cadillac stared very hard, but it was a broken ECM, since i got a new one the car runs nearly perfect.
now i've a problem with my idle gas... the car idles too low.
i drew in the screw from the ISC-motor because before the idle gas was much to high.....
now i want to have the correct idle gas, like described in the service manual but i dont know where to connect a tachometer for watching the RPMs of the car. in the book there is only written, that i should connect to the distributor but i dont know where.
then according to the manual i should run the car with 1500RPM and touch the ISC-motor to let it retract, then i should disconnect the ISC and should bridge A and B on the ISC-connector
okay then the ISC-screw should not touch the throttle and then the TPS sensor should have 0.5 volts with about 350RPMs
but thats the problem, without a tachometer i dont know how to do this procedure, and maybe somebody can help me in describing how to install a tachometer.
thanks a lot in advance
adrian
hey thanks for the quick answer..
yeah i know the negative to ground and positive to the connector on the coil, but on my coil there are only written B and an other letter but not "tach" or something else that could be a hint for me to connect it correctly...
i dont know where exactly to connect on the coil thats my problem, and maybe someone did it some time ago and can tell me where to connect it
but thanks a lot
2014 ELR
Did a little more Googling for you and found this:
GM HEI
Either go to the TAC terminal on the distributor or to the C- terminal/wire, which is typically a brown wire.
