1 - 2 of 2 Posts
1975 coupe deville
Can't figure out how to remove the bulbs.
Looking up under the rear of the car I can see the light housing but no easy, or even hard way to get to the socket.
1975 Sedan Deville
You need to remove the filler panels around the light lens. Once this is removed, you should see 6 (I think) screws that hold the lens to the light body. Remove the screws, carefully remove the lens (they often stick to the gasket, so don't crack the lens removing it). Then you can access the bulbs.
1 - 2 of 2 Posts
