1 - 15 of 15 Posts
84 Coupe w/500
I've got a all stock 72 Eldorado convertible that keeps heat sinking. I've did timing adjustments, new power/ground wires and starter but that didnt help. I put a ground wire at the starter also with no change. I ran new a new coil wire also with no change. Anybody beat this problem and want to share what they did.
When I see 'heat sink', I think of heat dissipating devices.
is this a NO-CRANK -
or a CRANKS-BUT-NO-START problem?
84 Coupe w/500
Sorry yall, a heat soak problem. When the engine is warm, the starter will turn the motor very slowly before it eventually starts clicking. The battery still has 12V. Even with a plug in battery charger/jumper turned to an extra 250 CC amps, it still turns over slowly till it eventually clicks. Let it sit for a couple hours, starts back up.
First check your timing. If that doesn't help, it may be the starter solenoid or maybe the starter itself.
do a STARTER DRAW TEST when the problem exists -
this will measure the AMPERAGE being pulled by the starter to spin the engine -
under "normal" circumstances - this should be somewhere around 125 amps -
84 Coupe w/500
Discussion Starter #10
My battery/charging system tester measures voltage and the starter used over 10 volts when starting. The 800cc battery had 585cca at 58 degrees during the test(tested while heat soaked, car did not start). It is a new starter also. I set timing dead on 8 degrees, gaped the points, the motor seems to love it...it runs good but has a small misfire at cyl 4. Now that I think about it, cylinder 4 has spark and fuel and seems to be actually burning the fuel. New cap, rotor, wires, plugs, capacitor, vacuum advance.. Tonight I'm going to chase that misfire, going to pull the valve cover and make sure the valve is opening. Got me wondering if a cam lobe is flat.
A flattened cam lobe should have nothing to do with the hot start problem you describe.
84 Coupe w/500
Discussion Starter #12
I wouldnt think so but an intake valve that doesnt open will make it harder to turn over, right? If not, I'll start chasing timing again. I'll start by verifying TDC on the timing pointer since there was a couple markers used.
this makes no sense - volts and amps are two COMPLETELY DIFFERENT things -
ALL electrical car parts use 12 volts to run -
the IMPORTANT thing in this conversation is the number of AMPS the starter is drawing to crank the motor -
I have no Idea HOW you got this number - BUT - if accurate -
the starter is drawing 215 AMPS of power - WAY too much -
either the engine IS that hard to spin - or the starter is defective -
BRAND NEW? or rebuilt? -
makes no difference - especially if it is a "house-brand" reman -
84 Coupe w/500
Discussion Starter #14
The battery is rated for 800 cca and was at only 585cca's at the time of the test, that is all. low battery but not low enough to cause my issues.
Here's a suggestion.
Disable the ignition somehow (so there;s no spark), and attempt to crank the engine. Does it crank?
If so, perhaps the timing chain is worn.
1 - 15 of 15 Posts
