I had a similar problem on my 68 DeVille. If it's not the brake light switch itself, I would check the connections on the neutral safety switch. A loose,dirty connection was the cause. Fixed that and got them back right away. In my car the switch is mounted to the steering column near the firewall. I don't know if that's going to be the same for you.
Good Luck!
Good Luck!
