Coupe Deville
Does anyone know why when I turn the A/C on on my 70 coupe Deville it makes a loud squeaking noise? I thought maybe the pulley needed some grease or oil so I sprayed some wd40 and the squeaking stopped but then as soon as it burned off the sound came back. Anyone have any ideas?
1979 Coupe deVille, 1995 Sedan DeVille (sold)
WD-40 is good for cleaning and getting stubborn bolts loose, but it is not a good lubricant. Its effects are temporary at best.
A squealing noise is usually a very worn or loose belt. The A/C compressor puts a load on all the belts, so check them all. How old are the belts? Each belt should deflect about a half an inch at the most. Never lube a belt! Belts are designed to grip a pulley so any lube will cause it to slip worse.
