I have a 67 Eldo with window switch problems. The driver's side work, but not the pass side. I suspect corrosion on conectors. I need help getting to the door connectors to clean contacts. Any help appreciated. thanks.
FWIW, I remember having a similar problem with a '69 Riviera. I remember that the rubber wire conduit from the door to the body was not corrugated like today. It was just a rubber tube that just sort of folded and the wires inside eventually just broke from being folded repeatedly in the same spot. Just a little something from memory lane to think about.
77 CDV, 06 DTS III, 69 FWB
Lyle,
Post your question on the Cadillac & La Salle Club's message board. You may have better luck with a response as the folks there are more knowledgeable about the older Caddys. Good luck.
Craig
