We have a 2004 6.0ltr all wheel drive Escalade with about 150,000 miles on it. Strange noise coming from the right (drivers side) bank, however, the engine was running smooth. It was diagnosed by a shop as a spun lifter. Having not worked on newer engines my response was SO!? They're supposed to. That's when I learned it had roller lifters like the 502 in my truck. They pulled the heard and found one of the lifter's roller with heavy pitting. The surface was smooth, shiny but pitted. I haven't tried to look down to take a peak at the mating cam lobe but suspect it to be damaged. The shop obviously recommended replacing the cam and lifters. Just to replace only the cam and all sixteen lifters was priced at $4,677. If they did the work I'd have a 17 year old engine with 150,000 miles on it with a new cam and lifters. I went to a second respected shop that priced out the same work at $6,017. Both shops quote around $8,000 or more for a long block replacement.
I started searching the internet for a long block. In my wrench spinning days there were new or rebuilt to select from. Now they've added "remanufactured". It looks like I can get a remanufactured replacement engine for around $3,000 - $4,000. I've done engine swaps and rebuilds in the past but not on a computer vehicle. I'm willing to give it a go on our Escalade particularly if I can save $4,000.
Questions:
1. Has anyone else had this lifter/cam issue?
2. Any pitfalls in doing the swap myself even though I have a fair amount of experience?
3. Are there computer recognition and smog issues to consider?
Any help/advice is appreciated!
Questions:
