When you say "at the top" , if it isn't damaged at the top ring groove, and just at the top edge/corner, I would polish out the nick and use it. Sort of depends on the damage to the side surface.
You would have to get an identical piston if you replaced it, because of a possible imbalance problem. Is a single piston available from your supplier??
Most vendors usually sell in sets only.
