Any suggestions??
Don't bother unless you're towing a trailer uphill at high speeds in Death Valley in July with the AC on. It's totally unnecessary and just another place to develop a leak and cause real problems.eagleworks4u said:Any suggestions??
I agree with mcowden.eagleworks4u said:Thanks
I was thinking that living in South Florida as heat indexes in the 90's the tranny cooler would help performance... I am just wondering how the sensors woud respond. My engine temp has peaked to 232 deg... As for leaks the fittings can be secured.I was a Aviation Hydraulics tech in the Navy:stirpot:
If you knew what you were writing about I would respect that comment. The question was pertaining to a 1994 Cadillac Eldorado which already has a transmission oil cooler of sufficient design. It does not need any help.zonie77 said:I put aux coolers on some vehicles. Not just racing or towing either.
If you worked in hyd you know if keeping fluid temps down is important or not.
PS. I was an AX.
91TexasSeville said:If you knew what you were writing about I would respect that comment. The question was pertaining to a 1994 Cadillac Eldorado which already has a transmission oil cooler of sufficient design. It does not need any help.
By the way, yes, I do have an understanding of thermal dynamics. I was an engineering team member involved in the development for the vacuum braze facility at the former Harrison Division of General Motors Corporation.
