1994 sedan deville 4.9
Good morning folks, a few weeks ago I was on the highway doing about 65 in overdrive when I suddenly felt like my transmission stopped engaging then suddenly kicked back in. When I got off the highway and pulled off from a dead stop while still in overdrive the car wouldn't move in overdrive or 3rd. I then put it in 2nd and got back up to around 30 mph and put it back in overdrive and the car continued to drive just fine. When I got to work I pulled the dip stick and found the fluid smelling burnt up and one piece of metal shaving on the dip stick. As of I can still put it in 1st and move it with no issue and reverse is also strong. My main question is can I still save this by doing the filter/fluid change or is it rebuild time for sure?
1985 Sedan DeVille
chunks of metal = something broken
1992 DeVille, 2013 ATS 3.6
so sorry to hear this drew =\ good luck my man. had you been hard on it or easy on it and it still happened??
how many miles did you get out of the trans??
Im with the other guys on this one.
I'm at 138 k now I pulled the pan and noticed out of the 3 lines one of them is easily removable..
