425 engine with a 501 intake vacuum routing
1660 Views 8 Replies 4 Participants Last post by  cjarvis
Hello everyone. This is my first time to ask for help. Ihave a 73 caddy and it had a 500 in it but I bought it with a blown 500, These people were gonna crush it, OMG. so I saved it and I went to a local salvage yard and I thought I got another 500 but turned out after I got in it the car that it was a 425.Had to switch some parts to make it work, I wasn't about to take it out after I put all new gasket on it, heads, intake, oil pan, new oil pump, etc. so anyway I got it in , then I had the wrong heads on , note: 500 heads DO NOT work on a 425 block, next I had to have to carb, rebuilt and finally it runs, but I can not figure out where all the vacuum lines go. some are missing, etc. where is all the wiring go. I have the altern. wired I think. any suggestions
1 - 9 of 9 Posts
Re: 500ci vacuum routing
moved here to new thread, instead of bumping a super old thread
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Re: vacuum lines
help[!!!!!]. I am in desparate need of where these stupid vacuum lines go. I have a 425 engine with a 501 intake. It runs but needs lines and wiring(some) hooked up. I plugged all the ports on the carb. and yes it does run. need help with lines, vac. brakes, power steering. it all works but about half.
ok, was i not clear?
i made this a new thread for you....then you once again bumped a 2+ year old thread.
if you're patient and stop bumping old threads, somebody may reply here.
I really hope ur not talking to me . Back off if you are bud. I am asking a question so if you know anything about it, great, if not then back off jack. I need assistance just like everyone else .
Does anyone have a specs on a 425
i'm not a jack, i'm a forum administrator, and your comment is against our rules
http://www.cadillacforums.com/subscribe.html
the ones you agreed to upon registering.
your time here is very short.
Yes, just chill out and someone that knows about the swap will chime in.
When I swapped a '68 472 intake manifold on my '79 425, it was pretty painless, only 1 or 2 holes on the intake had to be plugged... and the engine lost EGR.
BTW It is a 500 CID engine... not 501..... 501 is a sticker ;)
I just went through what you did, I kept the old 500 intake though, maybe put the 500 intake back on, I also took off all the smog hoses, and plugged some carb stuff, but all I had to hook up is the brake vac, vac adv, trans downshift, and air cleaner. Hopefully this helps. Thanks
1 - 9 of 9 Posts
