@Travis In the business they call that the 'margin of safety' and it's designed into nearly every part of a mass produced vehicle from seat belts to connecting rods.
I know my grammer sucks but oh well you get the point. You just don't want to admit Cadillac Slacked off and used the old V6 to cut costs and still charge the same because they're greedy.
No but I have common sense on my side. It's like putting AA batteries in a generator to power a house. You just can't do it. You need a stronger power source.
Do you seriously believe this is a valid argument? I suppose you could compare putting aa batteries in a generator to using a shimano bicycle motor into a cadillac deville as apposed to an automobile transmission.
Yes im sure they always could have made an even stronger transmission, but why do that when you already have one capable of handling the load.
Its like buying a brand new generator, because you bought a couple extra lamps.
I'll just step in here again with some food for thought, without getting technical...the 4l60 was another 60 series transmission with a similar torque rating that lived behind V8's in full sized trucks, vans, and SUV's, as well as sports cars such as the Corvette. Like the 4T60, it was GM's mainstay transmission for more than a decade. Was that also inadequate for V8 use?
They are different as far as the obvious configuration differences, but in most important ways, they are remarkably similar.
Either way, they are both a 60 series, which would indicate that they have the same/similar torque capacities. So is it just another V6 transmission put in the wrong place?
I'm not sure I don't know much about that transmission, I know there are several different versions that were used in trucks and such.
But the 4T60 that is used in Cadillac's are identical to the ones used in V6s in other GM cars. You don't see something wrong with that? Unless someone can chime in and say that they upgraded something I still believe it to be inferior and a error on Cadillac's part for putting a V6 transmission in a V8 car.
They are different, but in most important ways, they are remarkably similar.
The only thing I can add to this debate, for whatever it is worth, is that my '92 Deville 4.9 (4T60E) had 125K on it when I traded it and never had a problem with it.
4L60's were put behind V6's as well (the 4.3L, mostly). I don't see anything wrong with it. A 60 series is perfectly capable of handling a V6.
Don't forget that the vehicle's weight has an effect on the transmissions capacity, not just engine torque. A heavier car needs a stronger transmission, V8 or not. GM made a lot of heavy V6 powered vehicles in the last 20 years. Would you have felt better about the 4T60 if GM had used the inadequate 3T40 for their V6 powered cars instead?
You'll find cross-utilization such as these GM transmissions across ALL brands. This isn't a one time exclusive thing.
As far as I know, the 4T60 began service in GM's heavier full sized FWD's...the C-body Deville (V8 powered) and the H-body Lesabre/Park Ave/88/98. It was "designed" to be GM's strongest FWD transmission of the day - this wasn't any sort of forced carry over. GM already had the lesser 3T40 servicing it's smaller V6 powered vehicles.
What's confusing you is that the 4T60 was actually one of the smoothest shifting, strongest FWD transmissions of the day. Drive anything else from the mid-80's and you'll understand. It was successful enough that just a few years later, it's use became more widespread into the smaller W and A bodies. Don't fool yourself into thinking that they were "designed" for the later applications.
Wrong article, bro. 4T60-E didn't debut till '91, and as the article states, it's just a small evolution of the 4T60 with little significant internal change.
This is the root "design" you are talking about. It even talks about it's debut in '85:
You don't even know what transmission you have, or which one you are actually talking about, do you? On that note, I'm gonna go punch some babies.
Good luck getting to work the next few days without your transmission assploding all over the road! It's a wonder any of these cars are still rolling anymore! Damn GM engineers, they don't know nothin'
Has anyone had to replace the oil pan gasket on a 2001 Deville? The dealer wants over $3,000 to replace the gasket. Does anyone know of a cheaper place to get it done in northwest Illinois? Any help would be appreciated.
Having an intermittent problem with my 1985 Fleetwood (FWD). She only turns over about 50% of the time. I’ve tried the classic 3 issues (fuel, air, and spark) and have found no issues. Have been asking around and think it could be my BCM (body control module) but have absolutely no idea where to...
I had to replace the "mode" actuator because of a stripped gear. After I replaced it, air is blowing cold and then hot out of the vents. It also switches cold and hot from side to side. I did pull the wrong actuator at first. I pulled the one to the rear of the "mode" actuator, but I put it...
I was just gifted a 2004 DeVille by my father and just ran in to some trouble with misfires after a long road trip. The misfires happen while at an idle, low and high speed.
these are the codes I pulled:
P0455: EVAP System leak detected (large leak)
P0420: Catalyst System Efficiency Below...
