I've got a 94 eldorado with the 4.6, and i've got code p032 map sensor circuit open no other codes. After running a few minuites the exhaust manifold near the firewwall glows red. The map sensor has allready been replaced and i've erased codes several times and this is the only one that sticks around. Is it possable the CAT is plugged up and is causing the glow as well as throwing off the vacum level and triggering the MAP sensor fault. I checked the new andold map sensor with a vacum gauge and i think their good. any ideas?
I've also changed the ISC motor and it needs to be adjusted so it throws a code p030 ISC RPM out of range sometimes but i don't think thats part of the current problem.
