1 - 20 of 22 Posts
2010 CTS Sportwagon Premium 3.6 AWD
Back when I had my S60R, front lip options were basically limited to $600 carbon pieces (of which I destroyed one in a ditch), so it was pretty common for guys to find some cheap alternative. What we found over there is that the Subaru WRX/STI lips are really generically shaped, and so they fit on a bunch of different cars. Plus, being that they are so common and easy to find, they're cheap as dirt. I decided to test and see if one would fit on the CTS.
Here's what I bought:
https://www.ebay.com/itm/For-06-07-Impreza-WRX-STI-Sedan-Outback-Wagon-S204-Front-Bumper-Lip/222021760953?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
Prices vary, but anything for an 06-07 WRX would fit I imagine. Just be aware that if it has flaps on the side, they might not conform to the CTS bumper as well. That's why I went with the flat side lip.
It comes basically ready to go. My bumper was pretty tore up underneath, so finding places to drill mounting holes where shit wasn't cracked took a little searching, but in the end I could pretty much use all of the holes that came pre-drilled in the lip.
Pulled off the broken plastic under the front bumper, including the destroyed front valance. I think you could probably mount this with the valance still on, but it's hard to say. Might be worth trying. Standard lip installation steps applied. Just lined it up with a jack and jack stands after I put the car on ramps. The center mounting hole just lines up with the crease in the front bumper, makes centering it painless.
Once it's centered you'll see how much you have to trim on either side. You can kind of see in the photo, I had to chop about 1.5" to 2" off either side. Just hack sawed it and cleaned up the edges with some sandpaper.
From there it's just drilling and bolting. The lip comes with some self-tapping screws but they weren't really long enough, plus I have found they tend to pull out over time. So I just grabbed some spare hardware I had sitting around bolted it on with some lock nuts. Just make sure it's staying lined up as you work out to the edge mounting it. Mount it all loose at first and then tighten everything down.
Boom. $35 and 30 minutes later and you've got a front lip.
Discussion Starter #8
Update:
The other WRX lip you find on eBay will also fit with some adjustments via hacksaw.
Not as clean as the first one, but another option if you're interested.
Love it both ways!! Really adds a touch of muscle to the front end. Quick question about your headlights. Could you elaborate on them? Are they modified stock or aftermarket? Like the black background. Lastly, your Niche's are perfect for this car!! So nice in so many ways.
Discussion Starter #11
Thanks! Yeah I love how it amplifies the low, aggressive front end.
Headlights are Perde aftermarket. I'm on the fence about them. You lose the AFL functionality and then get a code on start up because of it. I like the looks of them, and the high-beams are a big improvement, which is nice because I usually take back roads on my way home at night. The right one gets a little condensation in it though, which is annoying. I imagine they both will start to get condensation over time. I still have my stock headlights, but the one cover is cracked from winter.
And thanks for the compliment on the wheels too!
Thanks for these options. I was looking for a front lip like this to at a little something to the front of my CTS. Didn鈥檛 want to get that rubber garage seal option they have all over the place. This looks better.
2013 Cadillac CTS Coupe 3.6 AWD Premium
Thanks Long. After I posed the question, I did a forum search and found that info too. After doing some research on the Niche Gamma rims, I see they only make one size in 18", which is the 18X8. My coupe has the staggered rim sizes of course, and I wouldn't want to change the rim size to 20" since I just bought a set of new 18" Michelins. Maybe in the future Niche will make the Gamma rim in bronze in an 18X9 variety.
09 cadillac cts4 09 yukon Denali
I see you're in Wisconsin, does this new modification blow the light fluffy snow into your windshield?
Discussion Starter #18
They are indeed Niche Gamma, 20". Thanks @Long for answering. I don't check on here as much anymore, looking to sell the CTS after winter so I haven't been doing any mod work to it lately or keeping up with the forum.
@Coneill no issues. I would imagine the actual aero effects of such a small flimsy lip is nearly zero.
2014 CTS Coupe Baroque Red Premium 2011 Black CTS Premium Coupe (Sold 2010 Sedan)
I love the lip as well. I鈥檝e hit the eBay link, but it doesn鈥檛 bring up the CTS lip for some reason. Anyone have a clue where else it might be available? I鈥檝e searched and searched but no go. Looks really cool!
Go ahead, blame me. Everybody does 馃檮
The link is correct.
TJ used a Subaru lip and tweaked it to work on the CTS. Instructions are outlined in the original post.
1 - 20 of 22 Posts
