1 - 10 of 10 Posts
STS-V 1 OF 3 BLK ICE & TANGO RED
I believe our stock rear wheel is 9.5" wide, the minimum recommended size for the 305/35/19 MT drag tire is 10".
Any thoughts, opinions, experience on this?
I'm on the verge of a slew of Timmy upgrades and I'm trying to address my traction issue before more power is added to the car, without purchasing a custom set of rear wheels.
06' STS V
Don't you already have a set of sweet ass 20" on your ride??
'06 STS-V, '17 CTS-V
My $0.02, for what it's worth...
A) Compound matters more than width in regard to traction. I'd understand the wider tires for looks, but not for traction.
B) 305 is, I think, too wide for a 10" rim if you want the car to handle with minimal "slop" entering or exiting a turn. Also, I think the tire size is too wide to run on the stock rim with regard to fender clearance because of the stock rim backspacing.
C) You can fit a 295 on the stock rear, however, but I think that you'll suffer from that "slop" mentioned above. 1MAdSTSV runs his that way. Whats a 1/4" difference in tread width, anyway?
D) Howey Industries site has new front 19x9 and rear 19x10 wheel sets for less than $1599 in the forgestar line for our six-lug rims. If you're putting in a "slew" of upgrades, why not do these too?
2006 STS-V, 2004 Pontiac GTO, 2008 Pontiac G8 GT, 1999 Chevrolet Suburban LT 4x4
On his point A above, the wider you go, will net you more contact patch, but the aspect ratio will decrease, shortening the sidewall. Meaning, for example purposes only, lets say you start off with a stock sized 275/40/19 and want to go wider, but maintain as near close to the stock diameter as possible, so you go 305/35/19. The 275/40/19 has an overall diameter of 86.9" and a 4.3" sidewall. The 305/35/19 has an overall diameter of 86.1" and a sidewall height of 4.2". The shorter the sidewall, the less flexible it is. In this case, you're losing a little bit of sidewall. It's not a lot in this case, but still, these tires don't have a lot of sidewall to begin with.
This IS great for Autocrossing and handling, but for putting down HP/torque from a dead stop, you're just going to blow the tires out from under it as the sidewall doesn't "absorb" that excess torque.
Watch a dragster, be it pro-stock or a nitro car. Note how tall that sidewall is. Now watch it under slow-motion during launch and what that tire does... It "wrinkles". This allows the contact patch to bite the pavement/surface, while the sidewall absorbs the excess torque.
2017xts vsport platinum, 2011EXT, gt500
86 in diameter?? Doesn't sound right.my math says tire is 4.2 on tall which would make the wheel tire combo 20 + 8.4. Or 28.4 in overall height
08 STS V, had 06 V6 STS
What size tire would you run up front on a 19" wheel?
19's are crazy expensive when compared to 20's (tires) so I never really considered it.
Sorry, I grabbed the circumference column.
Diameter/overall height is 27.7" and 27.4" respectively. I'm using OEM 19" wheels in my calc, not aftermarket 20's. That would make up our 1" difference.
Discussion Starter #8
Yes, but I need a set of drag radials and would like to use the factory 19. Thank for the compliment.
Rboughne1 said:
My $0.02, for what it's worth... A) Compound matters more than width in regard to traction. I'd understand the wider tires for looks, but not for traction. B) 305 is, I think, too wide for a 10" rim if you want the car to handle with minimal "slop" entering or exiting a turn. Also, I think the tire size is too wide to run on the stock rim with regard to fender clearance because of the stock rim backspacing. C) You can fit a 295 on the stock rear, however, but I think that you'll suffer from that "slop" mentioned above. 1MAdSTSV runs his that way. Whats a 1/4" difference in tread width, anyway? D) Howey Industries site has new front 19x9 and rear 19x10 wheel sets for less than $1599 in the forgestar line for our six-lug rims. If you're putting in a "slew" of upgrades, why not do these too?
For track days I would keep my daily set up of 20s and super sports. Those tires don't slide to the side for what I do but I need more grip for launches.
If I buy another rim it probably would be a a 20 or what ever size that has a lot of drags sizes available.
CMNTMXR57 said:
On his point A above, the wider you go, will net you more contact patch, but the aspect ratio will decrease, shortening the sidewall. Meaning, for example purposes only, lets say you start off with a stock sized 275/40/19 and want to go wider, but maintain as near close to the stock diameter as possible, so you go 305/35/19. The 275/40/19 has an overall diameter of 86.9" and a 4.3" sidewall. The 305/35/19 has an overall diameter of 86.1" and a sidewall height of 4.2". The shorter the sidewall, the less flexible it is. In this case, you're losing a little bit of sidewall. It's not a lot in this case, but still, these tires don't have a lot of sidewall to begin with. This IS great for Autocrossing and handling, but for putting down HP/torque from a dead stop, you're just going to blow the tires out from under it as the sidewall doesn't "absorb" that excess torque. Watch a dragster, be it pro-stock or a nitro car. Note how tall that sidewall is. Now watch it under slow-motion during launch and what that tire does... It "wrinkles". This allows the contact patch to bite the pavement/surface, while the sidewall absorbs the excess torque.
I'm tracking so what size drag radial would you recommend?
06 STS Rob said:
What size tire would you run up front on a 19" wheel? 19's are crazy expensive when compared to 20's (tires) so I never really considered it.
In that configuration the stock 18.
For clarity, I'm looking 2 place drags on the rear for drag use only. Drag sizes are limited, the 19" that I found was a 305 which made me post this thread.
08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
If you make the car hook hard be ready to fix the rearend. And all you need is a softer street tire I cut 1.78 60 ft times on street tires. I run a 305/35/19 on my Ctsv and its two wide for the rim handles like shit. At 80 and passing cars on the highway it feels like your on ice. 305/35/19 on stock Stsv rim will not work on our car. 295/30/19 realy doesent even work well but you can get away with it.
Discussion Starter #10
Right now I have Super Sports, what tires are softer?
So are you saying a 18" will be a better choice?
1 - 10 of 10 Posts
