Hi All,
I am experiencing an intermittent misfire in #3 cylinder.
The engine will run flawlessly one minute and misfire terribly the next.
Check engine light on, with codes PO154 (insufficient activity from oxygen sensor) and PO303 (misfire in #3}.
Replaced plugs in Cyl 1-3-5, there are no signs of bad plug wires.
The mis continues and is really bad at times.
Any help or suggestions would be greatly appreciated.
Thanks in advance.
Steve
[email protected]
Premium Member
Look under the hood on a dark night with the engine running to see if there are any extra sparks jumping around for starters.
Catera 97
I had a similar problem and it was the wire. I bought a cheap emergency wire pack ($25can) - adapted the coil end from the old #3 wire, and it cured the problem. Only then did I get a 3rd party replacement wire pack. I figured $25 plus my time was better to prove it before spending the big $ for the replacement harness.
Mine is a 97 and I made sure there was no oil in the plug sockets first (bad rocker cover gaskets).
