78 Deville 10 CTS-V Sedan M6 10 SRX Turbo Premium
I had an 09 CTS rental for all last week, not a bad car for a base vehicle! Anyways I really enjoy the turn signal that allows you to tap the stalk either up or down and will automaticly flash the turn signal 3 times and stop. I did some searching around and it looks like all cadillacs are coming equipt with this feature. My question is has anyone looked into adding this to their vehicle? Has anyone already added this? Is it just a basic flasher up grade?
2005 Cadillac CTS-V Platinum
That would probably be a difficult undertaking. It would likely require replacing the entire steering column / signal stalk for a unit that has a momentary switch built into it...and then from there a piece of custom circuitry that will flash the appropriate blinker three times
It could probably be done, but not very cheaply. Our V1 turn signal stalks don't have that momentary switch built into the steering column.
Thats what I wondering, I did a google search and it looks like the VW guys just have to replace the flasher relay to activate this feature. Maybe the momentary switch is in the flasher? IDK
2011 CTS-V Coupe
Once it's done be sure to list that in your mods/signature lol
NormV's link looks to be an easy install. If it's more than simple plug n play I don't think it'd be worth it, although it would be nice to have. My old boss's CLK500 had this. Hopefully it's easy but good luck either way!
