Our 2012 CTS Luxury (3.0 LFW) is known as Magoo. Many of her issues and adventures are documented on these forums.
-How long have you owned your CTS?
We've owned Magoo for about 5 months. Been driving her regularly for about 3 to 4 months.
-How many miles did the car have when purchased?
177K miles.
-How many miles does your car have now?
180.5K miles
-If any, how many times has the car left you stranded?
Almost left me stranded once. She overheated when the radiator fan motor died, but the gauge became critical and she started throwing error messages on the display as I was pulling in our driveway. It could've been worse.
She left her previous owner stranded a lot with electrical issues and dead batteries. I still haven't entirely fixed that. I've worked around it with a battery cutoff switch. She doesn't drain the battery with the negative cable switched off.
-How much have you spent on maintenance and repairs?
We spent about $500 on 4 new tires, about $100 to have those tires mounted and balanced, and a total of around $600 on new discounted parts for catch up maintenance and repairs. Most of the parts were from RockAuto and would have been two to three times more from a dealership. I am pretty OCD about using "original equipment" parts for most things. I do my own repair work, so labor charges aren't part of my accounting. Labor for what I've done would probably total 8 to 10 hours so far at flat rate.
I still have more repairs and catch up maintenance to do.
The sunroof still leaks badly from the rear drains. My work around for that is to always park her in the driveway pointed downhill. Our driveway is pretty steep where I park her. I've cleared the front drains already, they were clogged as well. The carpet stays dry this way. There's a lot of work involved in removing the head liner and pillar trim to get to all the potential issues in the rear drains. Ours seem to be disconnected or leaking at the top where the hoses attach to the sunroof frame drain nipples. The water is running down the outside of the drain hoses.
I think water (from the leaky sunroof drains) in the rear fuse block area was part of the electrical problems. It think September will be the month I really focus on the battery drain issue.
I also think the price you have is pretty high for an 8 year old car with average mileage.
Start your test drive at a drive through carwash. Take a 30 minute test drive after that, then check the carpet in front of the front and rear seats. If it's wet, the sunroof drains are leaking. That's a common, known issue with these cars.
The timing chains will go out. They last longer in the 3.0 than in the 3.6, but the design is the same, and the oil level check neglect is just as bad, which is what contributes to the timing chain issues. Replace them before you see metal in the oil and before you get codes. If you do them early enough, you may not have to replace the phasers. Chains and lower and intermediate sprockets run $200+ for the parts on the discounted sites or Amazon. With all 4 phasers and actuator solenoid valves, the price goes up to $750+ for the parts, and it's a pretty labor intensive job.
We paid $11,599 less to purchase Magoo than the one you're looking at, and I think we've gotten a good deal on ours. I expected a lot of repairs and catch up maintenance. We did get excellent maintenance records with Magoo, so I know what's been taken care of and what needs to be done.
