'05 ProCharged cts-V -Silver on Black
Ok.... Have Mickey Thompson drag radials on rear 305/35/18's
Have 255/40/18's gsd3's up front & it has worked out fine.
I'm gonna need some new front tires & I have 2 nearly new gsds's that were left over from the past ( 275/35/18's )
So I thought if I could use these in front I wouldn't have to buy new tires for up front.
In the past I've always kept tire diameter to less than 3% front to back & have never had a problem with stability control or ABS systems
So, I'm asking if anyone has gone over 3% difference in diameter front to back ? ( would be like 3.15%)
And has anyone run 275/35/18's up front "without rubbing" ?
where are people getting this 3% rule from?
It pops up on the tire size calculators ( if you go over 3% it comes up in red that your outa limits)
So, I assume it must be a standard limit for automotive systems
2004 CTS-V
I'll be running that front size on the track, it should work fine. (I might have to raise the front up a little, but that's no big deal)
As for the diameter difference, I would strive to stick within the 3% margin, but my previous set of tires actually were as much as 5.2% different than stock (but not that different from front to back) and I had no problems whatsoever.
