1 - 20 of 27 Posts
Hi new to the cadillac forum and the the cadillac world and as a owner I just love Cadillacs I have a 2007 cadillac cts v6 3.6l with 66,xxx bought it with 42,430 and it's pretty much stock right now just before I do some modifications just a quick question with rims I'm thinking about putting 22 inch by 8.5 and I have several tire sizes Tire size 235-30-22, 245-30-22, 255-30-22 or 265-35-22 what would be good for my car without modifications to the fenders or any other mod and with the offset the tires are good ?? any help or info would be good thank you
05 cts
22 are to big they look like they might fit in the back but they hit i think 20 is the biggest you can fit without any mods
Thanks for responding I appreciate it man oh so they maybe be to big you know if any cts owners have done put 22 inch on theirs ??
mgp carnage said:
gotta put 30 series tires on they will fit
Thanks so any of the info on tires I prescribed on my first thread work which will work better ? With the 30 series tire ?
Thanks mgp carnage for the reply do any of the tire options I describe on top of my thread work??
CTS Luxury Sport
You may be able to fit them on your car, but I don't know that I would advise wheels that big on the CTS. I have 05 cts 3.6l v6 with 20" vogues and sometimes turning makes the transmission feel like it's going to break (even just parking in my parking garage). Just my opinion though, I am not a mechanic so I don't know if that size wheels can actually hurt the transmission but it sure feels like it.
22s use to be common on the 03-07 cts. then people stopped doing it.
i run 20s, and like them. lots of 08-current cts's run 22s now
Discussion Starter #8
Thanks adometrius for your opinion and I understand I always wanted to put 22" on my cts but if it's gonna cause some problems like transmission problems or struts or anything like that I wanna avoid that and maybe go with 20" but just wanna know if anybody had problem with 22" like ghettomike saying that it use to be common back awhile but now with the newer models are common but thanks for your opinion and that's why I wanna keep searching more info here in the cadillac forum thanks
Thanks ghettomike and by any chance you know what they use to run on 22" with tires and if they had problems?? I been trying to search on the cadillac forum about owners with 22" on the first gen cts but just haven't come across any owner.
2006 CTS sport model/package
If you wanna run a 22", go for it. It's your car and you can go for the look you want. If you do a 22 I would say go with the 235/30/22. You should be fine. There is no reason to go with a bigger tire if you don't have to. Wider tires are for more traction. Trust me when I say traction wont be an issue. My 20's slowed my car down quite a bit due to the weight, your 22's will be heavy as hell.
Discussion Starter #11
Thanks Blayne for the response and your right about the look I want but I don't want to mess up the cadillac look is that I see alot of other cars with 22" and I thought maybe my car would look good with no problems but now I don't know if I wanna even put 22" maybe go with 20" with a lowering kit so how about on 20" what's the best tire series having low pro tires ??!
mgp carnage said:
agreed 235/30/22.
Thanks mgp carnage for the response anyone know anybody running 22" on first gen cts here on the forum ??
I did 20's with coilovers and 245/40/20 tires. I had to roll fenders. If you are just going with a lowering spring, you will be fine.
Discussion Starter #13
Would 245/35/20 work with lowering springs ?
I can't comfortably say 100%. There are others on here that probably run that size and I hope they chime in. Best bet is to get info on the diameter of that size tire and do some measuring!
Discussion Starter #15
So my car has a high positive offset between 34 to 45 so I gotta find some rims that has an offset between that offset ?? Can't go lower than my car's offset ??
The factory offset is 42 I believe. If you go lower, the wheels will stick out further and you run the risk of rubbing on the fenders. If you go higher the wheels will be in further towards the engine and the wheels may rub on the frame when you turn lock to lock. It's a pricey venture to "try" and see if it fits. I used a 35 offset on mine. They stuck out a touch more than factory. But I was fine with that. They look good. If I wouldn't have lowered it.....no problems. But, I dropped it a out 2". So I had to roll the fenders. If you do 20's with a 35-42 offset and just do lowering springs for a 1" drop then all will be fine.
Here is a link to my build, you can see in the last pics the rims on the car at the current ride height. There is shots from front and back also where you can see the offset. This will give you a bit of an idea.
http://www.cadillacforums.com/forums/cadillac-cts-first-generation-forum-2003/285029-my-06-cts-build.html
Discussion Starter #17
Thanks Blayne for responding and with helping me with info on how to set up my car and well I might go with 20" and drop it an 1" or not just 20" but I really appreciate it you a good man!
Discussion Starter #19
oxnard805 said:
22"s
<img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=112505"/>
Nice looking car man what is the wheel info? What kind of tires size and how wide the rims and does it rub or anything special you did to fit the wheels ??
Oxnard805, love the car. Looks amazing and beautiful stance to the car now. Well done!!!!!
1 - 20 of 27 Posts
