Did you break the PCV nipple off the factory intake, or did you break the fitting on the PCV hose?
If you broke the nipple on the factory intake, unfortunately I believe you have to buy an entire LH intake duct assembly as even though the nipple portion removes with just 2 bolts it isn't available separately. PN 84465552 for an LH intake duct assembly. However, I don't believe that part is used on the ZZP intake.
If you broke the tamper-resistant fitting on the PCV hose while trying to disconnect it, you just need a new PCV hose, PN 12670013.
