Looks like two of my 2017 pushrods!
Very typical for these engines!
2021+ as well.
Often because of defective lifters...
2021+ as well.
I would highly recommend to change the VLOM with the updated part. Who knows maybe I just needed to replace my rods when my issue occurred. If one of my 02 sensors fail then I will replace all four. When one of my controls arm fails then they all will get replaced including the front and rear sway bar bushings and end links. It will be cheaper to go that route then make multiple trips to the mechanic. I am going to buy a grease gun and grease my steering rod end links which are the only two parts that have grease fittings.Since I haven't heard the engine making noises that I haven't already alleviated, and I suspect I may have caused the push rod problem, I'm calling this one done. The first time I suspected a valve issue I found it to be the manifold bolts and gasket. I haven't had any check engine lights or any codes and everything sounds good now then nothing else is broken so if I change the lifters I mean what are the odds that those are weak and may fail. What's your suggesting I do is remove the head assembly and it's not needed right now so I'm not doing it I appreciate the concern. I'm just glad I'm the one working on this escalade instead of paying the dealer thousands and thousands of dollars. I can almost guarantee that of the two problems I had that I fixed, at least one of the times the dealer would have told me I needed all new valves and your well aware of the cost. The engine is purring now. I recently changed all the O2 sensors due to their age, barometric sensor, maf sensor and will be replacing more this summer just to be proactive, I rely heavily on this vehicle so I don't have a problem changing parts due to them being old. I usually pick some items up when I see them at a very good price as it's hard to pass up I just ordered a OEM backup camera for like 40 bucks brand new. I got all the oxygen sensors for like $160 and they are OEM. Not a bad deal.
