1 - 12 of 12 Posts
Has anyone had an issue with this Their trunk opening on its own? Took to the dealer and they said it was Corroded. Would fix for $560. Not to mention glovebox issue $650 fix. Unreal for a $70k car. No happy! Car only has 30k on it always garage kept.
2013 XTS Luxury
Mine does when the key fob bumps something else in my pocket. Has done this numerous times. I try and make sure nothing else is in my pocket now and I set the valet when parked at hotels just in case.
2019 XTS Luxury AWD, 2004 SRX N* AWD (gone)
On mine, the fob trunk release has to be pressed two times to release the trunk. I think it would not be common for this to happen in one's pocket.
Need more information...what harness is corroded and cause? Mine does not do that but it is new. No issue with my glovebox yet.
For the glove box:
2018 Cadillac XTS Luxury
Aren't the glovebox and trunk opening on their own an indicator that the battery needs to be replaced?
99 ETC 2004 SRX 13 XTS Luxury
I have 2013 XTS that would open trunk when carrying fob in your pocket the dealer change so you would have to hold button for several seconds in module before trunk would open . Tried to get them to change so you would have to press button two times but they couldn't do it at that time it was 2015 and that year from factory you would have press fob twice. The 2013 2014 can be changed to hold button for several seconds.
Discussion Starter #10
The harness Is on the inside trunk deck lid. I took it apart and found no corrosion. There is a service bulletin out on this issue (16-NA-169) It mentions corrosion due to water intrusion. My car is always in the garage and there is no moisture in my trunk or signs of a leak. I think the Dealer just pulled the bulletin and tried to take my money.($560) As far as the glove box issue goes. It is a very bad design. The actuator is on the left side of the glovebox. Push the button and right Side releases and the left side does not. I can pull down on the right side and Push the Latch and it releases the left latch of the glovebox. There has to be a better fix than having to buy a whole glovebox To the tune of $650. I did find a glovebox online for $225.00. Without a better design or better Actuator I have got to believe it will happen again. I will live with the glovebox issue for now. I am very disappointed with the quality of a $70k car.
At 30k, is bumper to bumper warranty not covering this?
1 - 12 of 12 Posts
