1 - 13 of 13 Posts
2014 Escalade Platinum ESV
This has been on going for a year or so. Cadillac replaced the battery and alternator a couple of months ago after it freaked out on me a couple times. The dashboard will blink, the running boards may go out and back in, AC will go to 74 degrees, the clock will change time etc. Took it to dealer last week when it did it again and they checked everything out but could find nothing wrong.
This morning it did it and the engine actually shut off and back on while I was driving. Did that twice.
:-( Help
2008 Escalade
The cable will look fine but it's not. Here are the links to what I used, but mines an 08'
Thanks guys.
Called Cadillac and they said I may have got a bad Alternator and they were going to change it out.
Should I go with the OEM battery cables or are there better aftermarket? I'm not as concerned about the cost as I am getting stranded somewhere.
Discussion Starter · #9 ·
Thank you,
I have an appointment with Cadillac to take it in Monday to change out the +/- battery cables. Hopefully that solves it. Had a hard time finding the OEM parts because of the strike.
I'm also changing out the driver & back drivers side door seals. Been driving around with what sounds like a window 1'' down since I bought it.
1 - 13 of 13 Posts
