1 - 14 of 14 Posts
2011 CTS Coupe FE3, 2003 Thunderbird, Gone 2013 ATS, 02 Deville
it is near the center, it is made of hard plastic and shaped like a handle. it glows in the dark.
Pull the release handle toward the front of the vehicle to open the trunk. Emergency Trunk Release
I could not down load the picture so I sent you the web address to see it.
well I don't know about why it will not take you there. when I click on the web address it take me there.
you just put the curser on the address and left click.
I found this I will keep looking '
There are three 19mm nuts on the bottom of the backrest. Then unbolted the 4 or 3 10 mm (silver) nuts behind the seat. You have to get into trunk or reach really far to get back. They're located towards the top of the back seat and run across horizontally.
Then pull the seat forward from inside the car and it should release
· 2014 ATS
Discussion Starter · #11 ·
I can't get into the trunk...i got the seat cushion out... the seat back had 2 small nuts with claps holding the bottom of the seat but i can't access the top ones
yes a found some sites that show the 3 top bolts that hold the top of the back seat and they can not be reached from the front.
I am sure this has happened to someone some where before but I can't find out how to reach the release handle.
best call a few Cadillac dealers and ask them how to do it. There is a Cadillac factory monitor that is on this site but I do not know how to reach them. I see him post at times.
2004 CTS Lux Sport and 2014 ATS 2.0T AWD Lux
The handle is mounted on the inside of the trunk lid a bit to the left. It is attached to a wire and the handle nests into a small indentation.
If there is nothing there, is there at least a small hole? Perhaps the wire was cut and the handle got lost?
1 - 14 of 14 Posts
