1 - 10 of 10 Posts
I noticed that my 2014 Ats has a weird AC quirk as of late. It started about a week ago. I have both sides of the AC set all the way down to 60 (it's summer in Texas lol) and for some reason the driver's side feels more like a 74 degree air stream
the passenger side still feels like 60
and when I turn the AC Off the air does get significantly hotter, so clearly the AC Is working.... Just not as much as I'd like it to on the driver's side
Could it be something wrong with my blend door actuator? this issue happens regardless if the sides are synced or not
Prev: 2018 ATS 2.0T NOW: 2020 CT4-V JR
I don't have experience with that problem, but based on similar topics in the past,
blend door is a good possibility.
If driver side has been plenty cold, but less than passenger, you might need Freon now,
but just a guess.
2013 3.6 RWD Premium - 2006 BMW Z4M
If the system is putting out plenty of cold air on one side but not enough on the other I believe it isn't a Freon issue but instead as said above the blend door, basically a flap to direct cold air to each side of the cabin as needed.
Charger Scat Pack- Auto/Corvette LS3-Auto
Old issue... I had it on my 14 also. Not repeatable.... some my dealer wouldn't do anything. In reality, they didn't want to tear the dash apart to fix the blend door/sensor.
2016 ATS4 2.0T and a bunch of other stuff....
My '16 did the same thing. Actuators were reprogrammed and it lasted about a month, then actuators got replaced and it's been good for almost a year now.
My only complaint is the displayed temp is wildly inaccurate, but at least it's consistent.
I have to say, this Caddy has the worst climate control of any ATC equipped car I've owned.
The manual heat/ac in my Ford truck is the best!!
2013 ATS 2.0T AWD
584264
There are four cabin air temp sensors, any one of which could be bad.
2013 Cadillac ATS
I wonder how that device is tested? It must be some kind of variable resistor based on temperature checked with an ohm meter.
1 - 10 of 10 Posts
