1 - 8 of 8 Posts
Please help me as I have consumed all my luck with this problem
About a year ago
The air conditioner filter has changed
And the skin of the air gate which is next to the engine
And since then my screen froze
When the vehicle was shut down and restarted, the screen did not work and the lighting in the steering wheel did not work
AC lighting works
i changed the screen
The receiver device has changed
HMI has changed
And it's still not working
Hatta when I came to a dealer who asked me for $ 16,000
I have tried all the steps the battery negative has been disconnected and still not working
But I noticed that when I reconnect the battery, the steering lights turn on for a second and turn off
Everything has been reviewed in a car
Is it possible that alternator..!!
the battery has been changed and upon detection of the alternator, the engineer told me that there is no problem with it
Please help me 馃檹
Cadillac xts 2013
6 V
598694
2003 Deville Base
Welcome to the forums! It would help a lot if you tell us the year/model/engine/trim so we know what car we're working on. Then, I can move your question to the correct forum page.
2019 XTS Luxury AWD, 2004 SRX N* AWD (gone)
Try checking battery connections and cables. Also, if the battery is a little weak it can cause weird issues. Maybe someone else here will have other ideas as well.
'93 SedanDeville 60 Special
You really need a wiring schematic to follow the wiring and look for a bad ground, wiring connector or dirty wiring connector pins
Could be a controller that controls that screen, maybe the BCM controller or the wiring for the cars network that controllers connect to and exchange information
Use a good OBD scanner and see if there is any DTCs (error codes)
1 - 8 of 8 Posts
