My Experiment was a success! I retro fitted the oem articulating running boards to my 2013 Escalade using the oem step assist module without changing the body control module!
youtube.com
Nice! That’s awesome! If anyone wants the recipe the parts list is pretty minimal mostly just wire and some specialize wire connectors.Congratulations!!!
That pretty awesome. My white 07 has fixed boards but my new to me black 07 has power boards.
I thought you were working on installing the integrated trailer brake controller GM left off every Escalade made. This is even better.
Congrats on that feat of retro-fitment. What did you use to override the function, the OE button pack? I’d love to see any pics you took.
Sent from my iPhone using Tapatalk Pro
There’s probably easier ways of doing this but I wanted to use the proper fuse location in the box to keep the install as clean and near oem quality as possible. I first noticed that fuse 65 had terminals, so I pulled the fuse box to checkout the X4 fuse block. It was already wired with a 10awg red/blk wire that ran into a larger harness that entered the truck just below the master cylinder. I lost the wire once it entered the truck, I carefully cut open the harness tape on the large harness under the dash to find 4+ 10awg red/blk wires. I then used a racer blade to make small slices into the wire to try to olm out the wire but couldn’t make a match so I ended up clipping it just before it entered the truck and ran it in a new loom next to the main body harness that runs along the driver’s side frame rail.I thought you were working on installing the integrated trailer brake controller GM left off every Escalade made. This is even better.
JX 200 Terminated Lead: 13575721 6-Way F GT 280 Series, Sealed (BK): Service Connector: 13580872 5-Way F GT 280 5.8 Series, Sealed (BK): Service Connector: 13582061 |
No I had the fixed boards, I always thought the articulating boards where cool but I was in it more because your not supposed to do it and for the challenge.These 5HP mods are awesome!
Errr... I thought 2013 already had folding running boards? Or, was it an option?
thanks it was a fun project, and your so right about the way they lure you into a new vehicle for a new emblem and few updated creature comfort’s.Love, love, love the attention to detail and congrats on unraveling all the urban legends about the BCM’s (lack of) requirement to make the motorized running boards go.
It’s funny how GM made all the special treats so difficult to add onto cross models. It’s a clever way manufacturers force consumers to buy a new truck instead of adding the missing options.
Imagine how frustrated dealers would be if customers knew how to add e85 capability with a tune & fuel sensor, BT and advanced cell phone control with a VCIM swap or motorized running boards. An aftermarket shop could dial in an 07/ 08 Escalade, Denali or even a 3/4 ton Burb up to 2014 accessory levels.
