HowHi, Guys!
As it turned out, my experience will be useful in the USA. I repaired my rear axle on my cadillac ATS 2013 AWD Performance. If you have 2.0T ATS, then you have 195mm rear axle, and not LSD. Maybe my experience will be useful for LSD, but 100% will be useful for those who have ATS 2.0T, CTS 2.0T.
It is my differential on picture.
View attachment 601554 View attachment 601555
View attachment 601556 View attachment 601585
After removing the axle you remove the cover, the differential mount, the wheels drive, we get a couple, knock out the side bearings. The heaviest are the rings on the side bearings side.
View attachment 601558 View attachment 601559 View attachment 601557
When we opened my differential, we saw that the large front bearing was broken. The bearings used in my differential were KOYO and F A G. The good news was there were numbers on the bearings. I found the bearings I needed on Alibaba (Shandong Hanke Bearing Co., Ltd. - Deep groove ball bearing,ball bearing)
Bearing numbers:
KOYO F-577158 - front large. KOYO F-574658 - front small. KOYO LM501349 / 14 - side. Seller Sarah Wang of Shandong Hanke Bearing Co., Ltd.
Numbers of gaskets and seals:
22772331 - cover gasket, 22993016 - rear axle shaft oil seal (2pcs), 92230584 - shank oil seal.
She helped with the choice, delivery and sent me all the photos with my bearings.
I found the repair manual for the 2015+ CTS 3 and explored all the information on repairing the rear differential. I made a manual for a mechanic. Rear Differential.pdf
The main thing is the tightening torque of the shaft nut, and of the rest of the fastening nuts. If you choose the wrong tightening torque, the couple may break.
View attachment 601583 View attachment 601582
The manual says: Tighten the NEW rear wheel drive shaft flange nut to 105 N.m (77 lb ft) until the pinion end play is just taken up.
Used differential in Russia - from 1500 $
New differential in Russia - from 3000 $
Used differential from Ukraine or other countries (without delivery) - from 350 $
I paid for 1 sets bearings (2 front, 2 side), all seals, the delivery, repair work - about 300 $.
I don’t know will the repair be profitable in the USA, but in Russia it was profitable.
If you have any questions, ask me. Who needs help, write. If someone wants to buy bearings, I will write the seller's phone number (Sarah Wang)
pasharin how did you remove the lock nut with the 4 points? I can’t find a tool to do it.Hi, Guys!
Bearing numbers:
Hi, Guys!
When we opened m, we saw that the large front bearing was broken. The bearings used in my differential were KOYO and F A G. The good news was there were numbers on the bearings. I found the bearings I needed on Alibaba (Shandong Hanke Bearing Co., Ltd. - Deep groove ball bearing,ball bearing)
Bearing numbers:
Should I describe the process of replacing pistons?
hey, can you please bring more details what to buy to replace open rear diff on cts (which is same as ats) with camaro one? thanksI think i got it figured out thanks to Dave from projectltg.com he advised me to get the ats rear axles and the should fit right in so i think it will all be ok lol
If I was to ask you what parts I need to rebuild my differential can you tell me I have a cyst 2014 3.45ratio rwd. No lsd.Hi, Guys!
Bearing numbers:
Can I get the number so I can get the partsHi, Guys!
Bearing numbers:
Do you know what yr diff you usedLoV to know the bearing part numbers!
That particular diff is $1600. But you can't even get them caddy has none!
THose particular rears with the cast iron housings go for $1600. Same problem with my CTS! THE PARTS ARENT AVAILABLE backorder indefinitely. I used the ATS rear and axles in my CTS. Perfect!
I just got my differential from China Shipping was only 200 bucks. 1800 for a new differential plus 200 for shipping. I thought I was going to get fucked on this but I didn’t. Going to take the old one and rebuild it. You can get the beings from over seas. I got the bearing numbers from this guy off here but I am going to check my old bearings when I take them off. Might cheap it for back up. Not sure yet. My differential was for a 2014 cts rwd 3.45 ratio. And it only took a week n half to get here.I went down the infinite rabbit hole on this one. I was unable to find anything. And with the world and what is going on in Ukraine everything f’ed. i ended up using a camaro difential. But i also bought a used one as a spare. A new differential one was 6 month back order and even then couldn’t promise it would arrive. The problem is gm has the patent on the bearing and no one will sell to just everyday customers took me a month to figure i couldn’t get no where. I found the bearing but with shipping to the us was $900
