Hi, Guys!
As it turned out, my experience will be useful in the USA. I repaired my rear axle on my cadillac ATS 2013 AWD Performance. If you have 2.0T ATS, then you have 195mm rear axle, and not LSD. Maybe my experience will be useful for LSD, but 100% will be useful for those who have ATS 2.0T, CTS 2.0T.
It is my differential on picture.
After removing the axle you remove the cover, the differential mount, the wheels drive, we get a couple, knock out the side bearings. The heaviest are the rings on the side bearings side.
When we opened my differential, we saw that the large front bearing was broken. The bearings used in my differential were KOYO and F A G. The good news was there were numbers on the bearings. I found the bearings I needed on Alibaba (Shandong Hanke Bearing Co., Ltd. - Deep groove ball bearing,ball bearing)
Bearing numbers:
KOYO F-577158 - front large. KOYO F-574658 - front small. KOYO LM501349 / 14 - side. Seller Sarah Wang of Shandong Hanke Bearing Co., Ltd.
Numbers of gaskets and seals:
22772331 - cover gasket, 22993016 - rear axle shaft oil seal (2pcs), 92230584 - shank oil seal.
She helped with the choice, delivery and sent me all the photos with my bearings.
I found the repair manual for the 2015+ CTS 3 and explored all the information on repairing the rear differential. I made a manual for a mechanic. Rear Differential.pdf
The main thing is the tightening torque of the shaft nut, and of the rest of the fastening nuts. If you choose the wrong tightening torque, the couple may break.
The manual says: Tighten the NEW rear wheel drive shaft flange nut to 105 N.m (77 lb ft) until the pinion end play is just taken up.
Used differential in Russia - from 1500 $
New differential in Russia - from 3000 $
Used differential from Ukraine or other countries (without delivery) - from 350 $
I paid for 1 sets bearings (2 front, 2 side), all seals, the delivery, repair work - about 300 $.
I don’t know will the repair be profitable in the USA, but in Russia it was profitable.
If you have any questions, ask me. Who needs help, write. If someone wants to buy bearings, I will write the seller's phone number (Sarah Wang)
Bearing numbers:
