1 - 20 of 33 Posts
I got a 2013 ats last year. Absolutely love the car, but it's been expensive. A few months after owning it I had a p0171 code pop up. Replaced the high pressure fuel pump. A few months later it came on again. Cracked vacuum lines on top of the motor replaced. Then when shifting into 3rd gear check engine light started blinking. Had to shut the car off. Cel said multiple misfire. Still happens sometimes. This year it's been on and off. Replaced all plugs, maf sensor. Last two weeks it hasn't gone off and is down shifting hard from 3rd to 2nd and 2nd to 1st. It's going in the garage Tuesday to get hooked up so they can try and read it. I've got a zzp intake, catless down pipe and Diablo i3 that I want to play with, but not till after it's fixed. I'm kinda leaning towards an o2 sensor. Any thoughts?
Also with the intake and downpipe will I need a custom tune from bnr for the Diablo i3 to get the full effect?
Thanks for any help
Its saying p0171, lean, bank one. I just cant pin point what it is exactly. I've replaced so many things as i stated before. All i can think is o2 sensor, maybe coil pack, or injector. I really have no clue. I just know there's been many problems with the p0171 code from what I've read.
· Vendor
ATS 2.0T gone, 17 Charger Scat Pack current
OP, as much as it sucks to type this, it sounds like you've lost a piston. I (and too many others) know these symptoms all too well. Do a compression check or get it to a shop to be checked out. Hopefully it just needs pistons and not a new motor.
· Vendor
That diablo tune might be your issue.
Hard to imagine something causing a problem that he hasn't even used yet?
Not sure why there's this impression that our tunes are somehow dangerous, but we don't kill 2.0Ts, 2.0Ts kill themselves as evidenced here and hundreds of other examples...
2013 ATS 2.0T RWD, DP, Intake, HPT, CC
a small vacuum leak leak after the MAF can cause this. Check that the intake tract and the intercooler for cracks, loose hoses, etc.
2006 STS
Thanks for any help
2006 STS
I would love to hear what you find out. My 2013 ATS is throwing the same code. I replaced the MAF sensor but it is still throwing the code. A couple weeks ago I took mine into dealer. They fixed an exhaust leak and changed my oil. A couple hours after picking it up from them the car throws code P0171. I took it back and they told me it was MAF sensor and wanted $272.00 to replace. I picked it up and replaced it myself for $75.00. Engine light went off for about a half hour but came back on.
ATS 2.0T Luxury AWD
here is what the repair manual for our car says:
P0171
ATS 2.0T Luxury AWD
just a thought because I replaced all sorts of sensors hunting down the culprit for a lean fuel mixture. I found that oil was coming up my intake track and splashing on the turbo sensor in the intake tube from the intercooler to the throttle body. check that sensor if there is oil on the sensor it will not read the correct temperature for the air coming out of the intercooler and will change the amount of fuel used. just a thought. i clean mine every month.
Discussion Starter · #15 ·
Sorry i haven't responded. I've been so busy with work. So i ended up replacing both o2 sensors. Didnt fix anything. Brought it to the dealership and found it was a small vacuum hose under the car that fell off. Twice its happened in the last month. It still has a blinking cel when it shift from 2-3 gear when im getting on it, but it goes away after 30 seconds. Guessing its just a misfire.Now the car is shuddering in low rpm. I was just on here reading of torque converter problems and failed transmissions. Not excited for the next step
Thanks for any help
I had the same issue about 2 months ago and sad to say it led to me finding out I had cracked pistons. Cadillac pistons from the year 13-15 are not the best. They upgraded them for the 17+ models. And I read that people are assuming its the tune. No its not my car was stock when it happened.
Discussion Starter · #17 ·
What did you end up doing? I've thought about that as a possible option to why its acting like that, but I've also read about the transmission shudder and the problem being the torque converter.
· Vendor
Seems the dealer didn't properly diagnose the issue. Still sounds like a cracked piston to me.
Discussion Starter · #19 ·
Yeah. I'm bringing it to the dealership next week for a diagnosis. Looks like i might be sticking a few more grand into it. If it is a cracked piston wouldn't i be seeing a power loss? I'm confused as to why it only gets a cel when shifting from 2-3 or 3-4. As for the shudder, I'm sure that's the torque converter as I've read in many other posts about transmission shudder.
· Vendor
The 2nd time it happened to me (cracked piston less than 5K miles after the first one was replaced) it would sometimes run fine for days on end, then randomly I would get some misfires and shudders as a result. Occasionally it would light up stabilitrak at low speeds then stall or try to die. I was not happy about the situation and didn't hesitate to go WOT and it would feel fine most of the time. I drove it like that for probably 45-60 days before I bothered to take it back to the dealer.
When the first piston failed it was barely driveable at all.
When it happened the 3rd time I barely made it home and once I got it in the driveway it wouldn't even start back up (piston killed the block).
A compression test should have been performed and will confirm the issue in most cases. The piston usually cracks near the skirt. My first one was literally falling apart at the bottom of the skirt.
1 - 20 of 33 Posts
