Anyone having a problem with the driver seat in in 2012 CTS-V not moving back or forward but the others buttons work? Dealership worked on it twice, New floor track installed, Worked for a week now same problem is back.
Agree!Take it back. They should warranty the work you paid for.
Took it to the dealer three times, Works for a few days and stops, Thanks for replying.Take it back. They should warranty the work you paid for.
Thanks, Will give it a try.FYI, that little electrical connector in the front of your seat is often a problem. If you sit in your seat, take your right foot and bring it straight back to your seat where the carpet comes up under the front of your seat. Reach down and feel for a little "block" and that is the connector. These tend to get corroded and therefore have bad electrical continuity.
Three times, Works for a few days and stops, It's getting to be like a wife, You soon learn to live with it.Agree!
Suspect: loose connection, faulty connector, partially broken wire, dead spot in motor rotation, poor fuse contact. It could also be an intermittent controller. Switches, including relay contacts, are always suspect.
Those kinds of intermittent problems are often difficult for highly skilled electrical and electronic techs. to find. They tend to go away and then almost always return.
Good Luck.
Glad you now have it fixed. Thanks.........Something to do with the gears not meshing together, All this after they replace the track, Glad I had a warranty.
I'm having the same problem. What was the fix?Glad you now have it fixed. Thanks.........
I've got the same problem now.Anyone having a problem with the driver seat in in 2012 CTS-V not moving back or forward but the others buttons work? Dealership worked on it twice, New floor track installed, Worked for a week now same problem is back.
