1 - 15 of 15 Posts
CTS
I purchased a 2012 CTS 3.0 about two months ago and I am having an issue with the car starting on its own. I turn the engine off, lock the door with my key fob and the engine will start back up. I do not have remote start and I have to use a key to start the car. When I get back into the car, I push the brake and the car shuts off.
I’ve taken the car to the dealership and they cannot figure out why it is having that issue. They told me that they contacted Cadillac and no one has reported that issue. I joined this forum to see if anyone else has had that issue with their car. I searched this forum to see if there existing discussions, but could not immediately discover and threads. Any help or direction is much appreciated.
2012 Black Diamond tricoat 3.0 awd cts
They all have remote start,post a pic of your fob.
2010 CTS Luxury
Press the lock button 3 times and see if it starts, I have an aftermarket remote start and I can use my Key fob that is identical to yours if i press lock 3 times. Or i can use the FOB that came with the system, worth a try.
Gone; ‘09 V, ‘13 V coupe. Curr; ‘14 PG Vsport prem w/Kona interior
^^^Yep.
The previous owner must have had a remote start system installed.
Remote start systems require a very specific signal to start the car, and onboard equipment necessary to carry that signal from the ignition to the starter.
Without that, and barring some crazy electrical gremlin, it would be virtually impossible for an unequipped car to start by pressing the lock button.
2008 CTS 3.6L DI RWD, GMPP new engine 11/2013
:hmm: If aftermarket remote start, then why does engine shut off when brake pedal is pushed?
2010 Cadillac Premium AWD CTS
I had a remote start installed on my 1997 cadillac sls. When I remote started the car and got in the car, and pressed the brake pedal it would shut off.
CTS
Discussion Starter · #9 ·
Thank you for the comments! I pressed the lock three times and it started! The mystery is solved. I have to watch pressing the lock now.
2010 CTS Luxury
Yes stepping on the Brake without the key in the ON position will stop the engine. Glad that worked for you, now you don't have to spend the money on a remote start, I believe the stock key fob was good to like 300ft or some where around that, my aftermarket keyfob is good for 1500 ft. You may want to see if you can find a replacement key fob for that aftermarket system to get more range if needed.
2010 CTS
what?? So if i press my lock button 3x my non-equiped remote start will work?? No waaaaaay. I cant try it now, i carpool, and not my week to drive.
And your dealer is a moron. They couldn't figure out it had a remote start (even aftermarket)?
1 - 15 of 15 Posts
