I just purchased a 2011 CTS Coupe Premium with 30,700 miles and when checked I am told the transfer case is bad. Is this a common problem cause I don't believe this kind of problem should happen at that low mileage point.
When you say it is bad... are you saying that the car is currently broken and cannot drive? Or are you saying that someone told you that the transfer cases are known to go bad?
Yes your car is known for having a poorly designed transmission output shaft and transfer case input shaft. There is upgraded/updated parts available to fix this problem. I myself am researching the costs of proactively having these parts replaced in my '14 CTS AWD.
Sent from my SM-G965U using Tapatalk
