2010 Escalade ESV
also can't adjust the steering column up or down???
Anyone else?
Thanks,
dlomi
2013 Porsche Boxster S, 2011 Range Rover Super Charged
I would check to see if you have power steering fluid. And see if you can use any WD to spray at any bushings around the steering column from the inside of the engine bay. Make sure the engine is off and cool. I'm not sure if WD40 is flammable so don't take the chance. If you still have problems take it into the service department. I hope this helps.
Your steering column adjustment is electric, and the column adjusters have been problematic in many cars I've owned. If it's not adjusting up and down, something is wrong.
