I've notice that my 2010 Escalade fan comes on way too early! The car can be cold and the fan will come on full blast. It's very loud and makes me wonder why it comes on so early. My previous 2010 didn't do this until the temp gauge got higher. My current one will sometimes come on when the temp gauge isn't close to getting to normal operating temp. Dealer wasn't much help when I asked them about it and warranty is gone so I'm definitely not taking it in there. Any ideas?
2007 Escalade EXT
Which fan, left or right?
The right fan (passenger side) comes on whenever the A/C is turned on and the freon pressure comes up to normal operating range. This is to draw air through the condensor coils when the truck is not moving so the A/C can exchange heat between the pressurized, hot freon and ambient air before it goes into the condensor.
If the LEFT fan (driver's side) is coming on that early, that's a problem in one of the temp sensors, probably just needs a new sensor. Not a big deal. Low fan speed, low temp sensor, high fan speed, high temp sensor.
2016 Escalade ESV Black on Black. Love It!!
Exact same problem. 2011 EXT both fan's I believe were coming on after starting engine and running for less then a minute. Under warranty replaced sensor.
2007 Escalade EXT
Thanks funhuman, should have been more specific.
The right fan operates by itself for A/C only. It can be running when the left one is not.
The left fan is the "command" fan and the right fan is a "slave" to it, so both fans come on at the same time (wired in series) when the engine reaches temp, vs just the A/C. The left fan should never run by itself, they both run if the left one comes on. At least, that's what the GM service manual says about the way they're wired...
None listed
I have the same issue as well. Both fans come on full force on start up. I cannot find the high and low temperature senors on any diagram. Doses anyone have a part number or diagram for these parts?
2013 Escalade esv Platinum AWD
I am having same issue. Where are the sensors for these fans? Can't even find a part when searching all I get is the coolant temperature sending unit.
The coolant temp sensing unit IS the fan input. Depending on year, engine, model, etc., the fan(s) will go to SLOW at some temp in/near the 220s and to FAST in/near the 230s - it's all electronic magic controlled by the PCM. As posted, one or more fans runs in SLOW any time some A/C or DEFROST function is set to insure airflow through the HVAC condenser in front of the radiator.
Specifics for YOUR car in its GM/Cadillac service manuals - online at www.alldatadiy.com
