Throw caution to the wind and make good use of your youth. The only concern I'd have about boosting performance is the state of the AWD system in regards to whether or not you have the corrected version, or the old.
High mileage does not equate to short lived following performance enhancements as long as the appropriate considerations have been made. Proper maintenance goes without saying. TheFlash is encouraging caution and there's nothing wrong with that, but if you can afford to experiment, by all means do so. The Cadillac forum, except for the "V" section, is not the best source by far for performance enhancements that actually yield measurable results beyond just testimonials and more noise from the exhaust.
Spend some time on the Camaro forum, different car, same motor and transmission and note the accomplishments and that the cars are not disintegrating from modifications combined with high mileage. The 3.6L is very well built and dependable when equally well maintained. The Camaro owners are responsible for establishing the boosted power limits of the stock 3.6L to be somewhere in the area of 600 hp at the crank, possibly more considering the failure in at least one instance could have been avoided and they all followed lots of abuse on the dyno and at the track before breaking so a mostly street driven car should hold up very well, especially at much more conservative performance levels. GM did not build them to the edge of their limit, there's a lot of reserve to take advantage of. It's the gadget failures that will drive you crazy with this car.
I doubt a cold air intake will offer any measurable benefit beyond possibly increasing intake noise if it has crossed your mind, a tune may change acceleration feel and shift character in a way you might be happy with, beyond that you'll have to put some thought into what you want to achieve and then decide how to get there.
Be sure to come back and report what you find.
