08 CTS4
Hopeing for some help from anyone with an 09 that could quickly take some pictures of the inside of their grill. I bought one off of ebay and it looks like it was taken apart and used to practice plastic welding on. I am going back and forth with this guy, the problem is I have an 08 and the grill is diffrent. Thank you in advance!
2019 CTS
The inner and outer sections are joined together by melting the plastic tabs. The process does seem to leave rather unsightly welds. Once you cut them off to separate the two parts, you are left with not enough tab to reattach. When I did mine, I used a hot melt gun to rejoin the pieces. It has held up fine but from the back side you can tell it's not factory. Fortunately no one can see the inside. Send me a picute of the back side of the grille, it's easy based on the above to tell if it's ever been separated.
