Need suggestion on steering wheel heat inoperative. Fuse location? Not where indicated on passenger side block? Thanks
2014 ELR
So according to the service manual it is a 7.5 amp fuse in the IP fuse block
584957
But the label in the service manual doesn't show it anywhere.
I would look for a 7.5 amp fuse.
I would also check the fuse 13 in the BCM
Good luck.
Good luck.
Good luck.
Thanks much for you prompt reply; will do.
'02 ETC CE, '04 CTS-V, '04 XLR, '13 XTS Platinum
Have you searched in the BCM fuse block located under the passenger side toe panel under the carpet?
