1 - 16 of 16 Posts
I have a 2008 STS4 with FE3/F55 suspension. The car has 96k miles. In the last few months I have had one rear shock seize, the other rear shock started leaking oil and lost it's dampening ability. Now the right front shock is starting to seize. Do these shocks/struts have a history of failure at less than 100k miles. It troubles me that they all went bad within a few thousand miles of each other.
05 STS4
Has shocks should be replaced every 25-50k. You got 100k. I'd say that's good for a strut / shock wouldn't you?
The only failure of magnetic ride shocks is leaking. They don't wear out. Everything fails at some point.
Cadillac STS
I wouldnt say that is good at all in normal usage
Yes..everything fails at some point but shocks failing, under normal driving conditions, with that mileage is not class leading
Warren
2008 STS4 V8 1SG Platinum Edition
My 05 Magnetic shocks started leaking at 130k. One member on the forum drives with them empty. Says ride is still decent but who really knows...
2006 STS 1SF N* RWD NAV F55
I have been on line with a warranty company, who would like me to get a Extended waranty
with them, and I more or less, said, some companies do NOT cover shocks or struts, because
the mechanic, didn't say the correct name for that part,in trying to get it covered under
extended warranty, the guy came back with: "No" extended warranty company, Excluding CPO, covers
shocks or struts ? Any comments on this, as I would Like a company to cover these, as
they are VERY expensive. Talking F55 Only. Please mention Companys names. Thanks
Happy Motoring :):suspect::stirpot:
Premium Member
Happ Motoring :):suspect::stirpot:
Set a few dollars aside in a piggy bank every month for shocks/struts and you'll be miles ahead of the game. Warranties don't benefit anybody but the guy selling them.
Cadillac STS
dont know about that
anyone who has had head gasket or magnetic ride control( or ISS) repair done under warranty would disagree with you
However
the other stipulation is most warranty companies these days a have a financial stipulation
their total obligation is only covering cumulative repairs up to the book value of the car
So..as far as these cars have typically lost resale
a couple of major repairs...say HG and suspension repairs could be more than the value of the car
keep that in mind
Warren
'18 XT5 AWD Premium Luxury, '08 STS-4 N* 1SG, '04 Bonneville GXP N*
Given my situation I'd be happy with 100,000 miles. Heck, all four of mine have been replaced and I don't even have 100,000km (about 62,000 miles) on my 2008.
05 STS4
turnne said:
I wouldnt say that is good at all in normal usage Yes..everything fails at some point but shocks failing, under normal driving conditions, with that mileage is not class leading Warren
Lol so you telling me Lincoln air ride last longer? How about the bilsteins used in Audi? Youre SADLY mistaken. Take you over 100k worth of pot holes and see how you hold up. It's always something to bitch about with these cars when it comes to you.
'11 CTS-V Coupe M6, '05 1SG STS4 V8
I guess I'm glad now that my car was equipped with passive struts, LOL. My car has 147k and they don't show up on the service records so I assume they're original. Not bad.
Cadillac STS
Lincoln even use that air ride any more?...
Just another reason that those cars became throw away cars as well...low resale and high repair costs make a car meet the junkyard quickly
As for bilsteins...I have 3 Mercedes benz vehicles that went well over 100K miles and no issues what so ever
Your comment about 25-50K miles at failure time is below class standards
It may happen..frequently to a brand
It just means like those Lincolns etc it just gets to the junkyard that much sooner
Oh...and by the way have you noticed that Lincoln has completely changed their sedan line up?
Perhaps there was a reason why
Warren
I purchased my 08 with an after market warranty from a Chev dealer. They told me they cover just about everything. Well the lane departure module died, the parking brake needs adjustment and the trunk struts were gone. They covered nada. So within the month I just cancelled it and got my $2500 back. Take it for what it's worth. I think unless they are B2B they're worthless.
Cadillac STS
you bring up an interesting point
At one point a few years ago..I had a late build STS..02....with the F55 Mag ride
I also had a late model Aurora V8 as well that I put some new Monroes on all around
the suspension on the Cadillac would have been 4x what the Aurora was to replace
The Cadillac was "slightly" better....say $500 more if I put a value on it
Suffice to say I doubt you are missing much with your passive set up on your STS vs the F55 set up
I traded in the 02 STS at 127K....it had been fairly problem free ..but at that point the suspension replacement would have been at least as much as the car was worth
Warren
yes...unless it says its covered explicitly...then I would make the assumption that it is not
When mine was under warranty they replaced some components of the drivetrain to fix the "chuggle"..a water pump....the drivers door receiver and a few other odds and ends
I think they covered about $3500 worth
On another note..I think my 02 was a more reliable car
Warren
05 STS4
Last I checked most Lincolns were built on platforms taken from Ford...Not a real testament to Fords trust in letting their LUXURY brand lead the way, its supposed to be trickle DOWN technology, not up.
Bilsteins failed 3 times on my Camaro track car... running Konis now... not a single failure...
03 STS, 1 rear strut failed at 110k in 2014... I would say that shock proved its service life.
Why don't you think most aftermarket warranties don't cover shocks/struts, because they are considered a WEAR AND TEAR item. Like tires or brake pads, the more you use it and abuse it the sooner it's going to fail.
Discussion Starter · #16 ·
We got the strut replaced this week. It had an obvious oil leak. The car rides much better now. My theory about the inconsistent ride quality is that the MRC "gets confused" as oil is lost. When first starting off with the car in the morning the suspension was pretty compliant. After a few miles the bad strut got very harsh. The rebound dampening was most noticeably affected, like an old 90/10 drag racing shock. The intent of the original post was to discuss any known problems with these suspension components. The extended warranty discussion has taken it in a different direction.
1 - 16 of 16 Posts
