2008 sts
electrical problem locking and unlocking rear passenger locks.
when i used the remote control just the front locks open the rear ones i had to push several times untill beraly trying to unlock the door, same problem at locking it, if im inside and i try to use the manual switch the problem still untill after various attempts finally works, can someone explain me whats happening? thank in advance, by the way still under warranty.
2006 STS 1SF N* RWD NAV F55
Try pushing the unlock on the remote Two or more times, see if it works then.
All doors lock automatically at about 3 or 6 MPH. Does that work ?
The First Push will NOT unlock the Rears .
2008 sts
Discussion Starter · #4 ·
i pushed the bottom several times and the left pass side lock still stuck, i can heard that is trying to unlock but isnt working, sometimes happend with both rear lock but most of the time with the left side.. what do you think ? anf than you for your response,
2008 sts
Discussion Starter · #6 ·
If you hear them 'trying' it can't be the Vehicle Personazation settings. Stickey lock solenoids should be replaced. If you've got a warranty, why fret?
i was just wondering about if is normal about this type of thing happened to a pre-owe Caddi, i'm not familiar with this car, by the way an appointment set up at the dealer to get this resolve.... any clues about what else could be wrong on this car? it has just 20.000 miles and warraty expired next month...
