'05 Escallade ESV Plat., '16 Z51 Corvette, '03 Avalanche, 12 Lexus IS350C
I've been chasing a possible can-bus issue on a '08 EXT without much success.
The truck seems possessed at this point.
Codes:
C0242, C0900
U0073, U0100, U0101, U0121, U0140, U2100
P0327, P0513, P0521, P0575, P069E, P0700, P0703, P0826, P0856, P0989, P1682, P2544, P2610
I know that one bad module or bad can bus wire can disrupt the entire system and trigger codes from everywhere.
I've checked the terminating resistor at the rear and checked the one in the ECU and got 120ohms.
When I check resistance at pins 6 & 14, I get something completely different than the expected 60 ohms. It started out around 25 ohms with everything connected and changes with the more modules I disconnect. I've removed every module under the truck including the terminating resistor, BCM under the dash and the connector under the driver seat and I think I'm sitting at 70 ohms. The resistance would change for each module disconnected. With all that disconnected, I tried connecting my meter to the plug with the terminating resistor and the pins for the ECM and it shows open circuit which I would expect with both terminating resistors disconnected. I think I still show open circuit when I reconnected the rear terminating resistor. Why am I getting a reading inside the truck when both are disconnected?
A couple times the truck would not shut off for several seconds with the key off and removed. I replaced the ignition switch with no change.
Another goofy thing going on is with the key removed you can hear a cycling high-pitched noise and then some solenoid is being cycled inside the transmission.
Occasionally, it will start cycling the rear shock air pump.
I removed a relay in the harness under the brake master cylinder and all that stopped. The relay checked out fine. There is something cycling it.
The truck will also ding the key in reminder randomly as well, again even with no key in.
During idle, the tach and temp gauges flutter and the truck idles poorly.
It won't shift out of 1st gear.
The key reminder randomly dings.
I'm getting about 7.5v at each pin 6 and 14 (hi and low can bus) I didn't write them down, so I'm going off of memory.
We've read that a common problem is battery cables, so we ordered them to be delivered Friday. The battery checked out fine.
Until then, I think I'm going to reinstall all the modules and reconnect the transmission connector and double check voltage at pins 6 & 14.
I found a Bulletin No.: 08-07-30-021G and will be going through that, though the truck always cranks and starts up.
Has anyone run into this and have any other ideas or specific items to check?
Codes:
C0242, C0900
