2008 Escalade ESV
Escalade was running fine, pulled in driveway parked and when I came out 2 minutes later turn the key and nothing. Gauges roll up as usual, but starter doesn't engage, no noise nothing. Battery is at full power and no codes etc. Any ideas? Figured maybe starter not engaging but with key on and put into gear to move slightly then put back into park, nothing. Figured maybe steering wheel needed to be moved one way or the other to lock, again nothing. Steering wheel is not locking after pulling key, and no chime with key in and door open. Could this be an ignition problem ????
Escalade ESV 2007
It seems it is not detecting the presence of your key. Did you try with your second key? Does the remote start work? I know some keys do have some kind of thing inside that activates the ignition system, but not sure if the escalade does have it.
