Hey gang,
I recently picked up a 2008 Escalade ESV that has a few issues. When I install the battery most everything seems normal. I hear a few dings from inside, when I open the door the dome light comes on, etc. when I turn the key on the dash comes to life and appears normal then when I try to start the vehicle I hear a click from a relay in the fuse/relay box on the fender but nothing happens (doesn't crank over). Again all else seems normal when I do this (head lights turn off, radio shuts off etc) when I release the start the radio and lights come back on. I do have a few codes showing, P1682 and P0315. Also when I turn the ignition on I can hear the air pump come on and a fan or other motor up by the sun roof but I don't think the fuel pump runs. It's possible there are some damaged wires in the wiring harness but I haven't found any at this time. The fuses all look good and the electrical connections look clean. One other thing I noticed is the check engine light stays on after the key is turned off and removed.
Any thoughts on where I should start?
