2006 Cadillac CTS [] 2008 Cadillac DTS
Oh my problem child,
Just did new valve cover gasket, sparkplugs, injectors, and intake gasket.
I have a slight jerk at idle when my AC/Heat is on. I do have a leak with my power steering, but im not sure if this is affecting this. It was doing this before I had those mechanical issues repaired. It wasn't doing it for a solid 2 weeks either.
No engine codes either... I have been running regular though, and this occurred after filling up at a station I usually dont, and I only use top tier stations.
1968 Deville convertible
I would see what happens with new gas but hard to say when you aren't throwing a code
It almost feels like a misfire only at idle and only occurs at operating temps... I just put new plugs and injectors, I might throw in some new coils. I saw a similar post on here and that's what he did, he never replied if it fixed it or not but at 130k miles... I could see it being a coil because when the AC/heat is on it puts a load on the engine and a delayed coil could be the issue. I also gotta slap a new power steering pump or the high pressure line. I have a seepage issue and haven't gotten around to looking at the cause just yet.
Ahhh gotcha well you could always just test the coils out. Just google how to test coils if you are unsure.
