I replaced Fuse Number 27 (J Type Fuse 30amps) and it works.
The old fuse looked fine through the viewing both although the plastic was old and brittle to the touch so I said alright just replace it and sure enough both fans powered up. Both fans should turn on without the A/C on when the Desired Fan Power Vs Coolant Temp reaches 213F or (101C) and they do. However what caused this fuse to blow out to begin with? I still don't know?
Also I think the factory 213F temperature is to high for this engine to reach for the fans to come on, is there a way to make these fans come on when the temp reaches 205F? A simple solution for me is to just run the A/C 24/7 not an issue as I live in Florida and put some coolant additive to keep the coolant temp down, and yes the additive does work In dex6, ran it for years. But I wish there was a way to make the fans turn on at 205 instead of 213 if seems way to high for this aluminum engine as it will easily reach 220/225 for a couple minutes before the fans start bringing it back down to the 200 mark.
Someone from another forum sent me the GM Manual page for this
This how the fans operate:
Quoted from the GM manual for the 2008 Cadillac DTS:
"During low speed operation, the ECM or PCM supplies the ground path for the low speed fan relay, which is fan 1 relay 33, through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closed the relay contacts, and supplies battery positive voltage from the fan 1 fuse 27 through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the series/parallel relay which is fan 3 relay 32, and the right cooling fan. The result is a series circuit with both fans running at low speed.
"During high speed operation, the ECM or PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3-second delay, the ECM or PCM supplies a ground path for the series/parallel relay and the high speed fan relay, which is fan 2 relay 31, through the high speed cooling fan relay control circuit. This energized closing the relay contacts, and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit, to the right cooling fan. During high speed fan operation both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
supplies battery positive voltage from the fan 1 fuse Number 27 through the cooling fan motor supply voltage circuit to the left cooling fan. The fuse looked fine as you can see through the viewing box so I did not think it could be this fuse but I put a new one in and both fans power up.
When the request for fan activation is withdrawn, the fan may not turn OFF until the ignition switch is moved to the OFF position or the vehicle speed exceeds approximately 10mph. This is to prevent a fan from cycling ON and OFF excessively at idle"
And I got a coffee afterwards in my Cadillac. Hence my username.
