1 - 14 of 14 Posts
2008 CTS 3.6L
Hello, I need help to locate the lighting module for my 2008 CTS. Can anyone tell me where it is located? Thanks
Go ahead, blame me. Everybody does 馃檮
Welcome, HST111--
Can you explain what your specific issue is?
2008 CTS 3.6L
Only the front passenger side turn signal and hazard light stopped working. I checked the bulb and it is good. I confirmed good conductivity from the pins in back of the light housing, but when I checked the plug ther was no current going to the turn signal. I want to check and possibly replace the lighting module, any other suggestions would be appreciated.
2008 CTS 3.6L
Checked under both fuse boxes and can't find the lighting control module. Anyone know where its located on the 08 CTS 3.6L? Doing more checking I found BCM3 10 amp fuse is blown now. I'm now going look for short somewhere, does anyone know where I can get ground distribution diagram on this?
2013 Black Diamond CTS4 Premium Coupe (sold-09 CTS4 DI Black Raven/Ebony)
Sadly, it happens. This is the cheap support site. Now if we charged a diagnosis fee of say $99, you would eliminate a lot of questions. :p :ROFLMAO:
Even at $99, we're still cheaper than the stealership.
yea, but it would prove that somebody at least has a slightly vested interest in the solution. And the fees could go to supporting the new site, which if folks haven't noticed, the folks in the background have been investing a lot of time and effort making steady improvements to make the site better. (y) (y)
They make a boatload of cash on vendors and advertising and likely wouldn't want the liabilities associated with diagnostics for dollars.
1 - 14 of 14 Posts
