2008 Buick Lucerne cc’d 4.6 v8
Hi! I lowered the left side of the subframe but it is still hitting the frame. Any tricks for removing g this harmonic balancer
Have you tried going through the wheel well? I think there may be an access panel that you can remove.
Yes! Two days later I finally got it off! But now I cannot remove the blasted seal!!! I’ll try to update the title of this post.
many tips for removing this front oil seal? It broke the seal puller
574353
I never found the access panel. It just took lots of breaks, patience and swearing. I think the biggest part was finding how low to lower the subframe. I was stuck at only having 1/4th of an inch left to remove it for about a day.
I took a long crow bar and with the subframe lowered, I wedged the crowbar and the balancer came off from the bottom and lifted upwards.
