2007 Base,6.2,AWD, 194000
Cruise works until I use any other switch. Window, heat, fan, does not matter. The second I use other switch CC disengages. Also true for Mirror heat. When I first bought it this year WSW would also stop if I used any climate controls. My V1 Radar detector starts going crazy constantly cycling thru modes (plugged into Cig Power Out), when switches used. Is this a body control module problem? Also getting Stable Trac/ trac control Fault on info center sporadically. New battery.
Thanks for help.
Installed new(not rebuilt) alt. 160 amp. scanner showed old one at 10.5 v new one shows 12.5 v . scanner says still not correct. Someone has replaced ground from block to body with cheap one so that and checking BCMground will be next. Stay tuned Thanks.
